Chủ đề: code matlab
12-08-2014, 06:47 AM #1
code matlab
không biết cộng đồng mình có quan tâm tới matlab trong viễn thông không nhỉ. nếu có em nhờ các anh (chị) sửa giúp em đoạn code em sưu tầm được vê TC (phân tập thu trong mimo). em xin cảm ơn
lỗi khi chạy :
Undefined function or method 'Transmit_Generator' for input arguments of type 'double'.
có file txt đính kèm bên dưới cho anh em dễ test!
code:
N_datapacket=600; %number of data packet
for m = 0:4:4;
N_receive=2;% number of receive antenna
N_transmit=1;% number of transmit antenna
SNR = [2:2:30].'; % signal noise ratio
N_datasymbol = 30; % number of data symbol
N_fft =128; % size of FFT
N_cp = 10;% CP length in normal mode
Powersignal= N_transmit*1; % power of noise-free received signal N_symOFDM =N_fft + N_cp; % OFDM symbol length after CP insertion
L = 5;% number of resolvable multipaths
PDP = exp(-(0:L-1)/4)/sum( exp(-(0:L-1)/4) ); % function of Power Delay Profile
M_QAM =64; % MQAM modulation level used
length_subcarrier = log2(M_QAM); % number of bits per 1 subcarrier
BER = zeros(1,length(SNR));
tic
for SNR_index = 1:length(SNR)
No = Powersignal/(10^(SNR(SNR_index)/10)); % power of AWGN
for p = 1:N_datapacket
disp(['SNR=', num2str(SNR(SNR_index)), '; dataPacket=', num2str(p)]);
[x,data_bit_seq,data_sym] = Transmit_Generator(length_subcarrier,N_fft,N_datas ymbol,L);
h = zeros(L,N_transmit,N_receive);
H = zeros(N_fft, 1, N_receive);
for nr = 1:N_receive
h(:,1,nr) = sqrt(PDP.'/2).*( randn(L,1) + 1j*randn(L,1) );
[y,Y_FFT] = Receive_Generator(N_transmit,N_receive,L,N_fft,No, h,x);
for k = 1:N_fft
H(k, 1, nr) = exp(-2j*pi*(k-1)*[0:L-1]/N_fft)*h(:,1,nr);
end
end
recoverbit = zeros(1,length_subcarrier*N_fft*N_datasymbol);
for j = 1:N_datasymbol
recoversymbol = zeros(N_fft,1);
for i =1:N_fft %go through all subcarrier
y1=0;
h1=0;
if m == 0 % No Diversity
y1=Y_FFT(i,nr,j);
h1=H(i,1,nr);
x1=y1/h1;
recoversymbol(i)=[x1];
elseif m == 4 % Threshold Combining
Powersignal = N_transmit*1;
threshold = Powersignal; nr = 1;
count = 0;
while ((abs(H(i,1,nr)) < threshold) && (count < N_receive))
nr = mod(nr,N_receive)+1;
count = count + 1;
end
recoversymbol(i) = Y_FFT(i,nr,j)/H(i,1,nr);
end
end
recoverbit((length_subcarrier*N_fft*(j-1)+1):length_subcarrier*N_fft*j) = MQAM_Demodulator(recoversymbol,2^length_subcarrier );
end
BER(SNR_index) = BER(SNR_index) + sum( abs(data_bit_seq - recoverbit) );
end
end
BER = BER/(N_datapacket*length_subcarrier*N_fft*N_datasymbol ); switch(m)
case 0
figure(1)
semilogy(SNR,BER,'b-','LineWidth',2);
hold on;
case 4
semilogy(SNR,BER,'r-','LineWidth',2);
hold on; otherwise
end
title('Receive diversity technique TC'); xlabel('Signal noise ratio (SNR) (dB)'); ylabel('Bit error rate (BER)');
legend( 'No diversity',...
'TC '); grid on
endView more random threads:
- 15 câu nói bất hủ khi chơi game bài online
- Driver BLDC bị cháy trở
- hướng dẫn dùm mình đồ án này với
- Giải thích dùm mình hàm Demorgan
- Anh/chị cho em hỏi về code arduino interrup với ạ
- Kít phát triển 8051 HC6800
- Giao tiếp HMI với vi điều khiển?
- mobile robot
- Giúp hiển thị số vật đếm được trên 1 led 7 đoạn ( PIC16F887 )
- Giúp tạo thêm hiệu ứng cho LCD 20X4 hiển thị giờ-phút-giây
Svakom Vick là gì? Công dụng và...
Hôm qua, 09:47 PM in Rao vặt tổng hợp
