Kết quả 21 đến 30 của 33
Chủ đề: thiết kế chế tạo robot dò đường.
09-19-2014, 04:35 AM #21
Gửi bởi trantu93
Gửi bởi thiet_kt
09-19-2014, 04:41 AM #22
vay bác sinh năm 1987 à?
em học hệ quân sự(gần năm cuối.hihi)
09-20-2014, 07:55 AM #23
Gửi bởi mta_cdt
09-20-2014, 12:30 PM #24
Gửi bởi trantu93
Mã:/***************************************************** This program was produced by the CodeWizardAVR V2.05.0 Professional Automatic Program Generator © Copyright 1998-2010 Pavel Haiduc, HP InfoTech s.r.l. http://www.hpinfotech.com Project : Version : Date : 5/2/2014 Author : NeVaDa Company : Comments: Chip type : ATmega16 Program type : Application AVR Core Clock frequency: 8.000000 MHz Memory model : Small External RAM size : 0 Data Stack size : 256 *****************************************************/ #include <mega16.h> #include <stdio.h> #include <delay.h> #include <alcd.h> #define ADC_VREF_TYPE 0x00 #define chanel 8 //const char dir=0; int count=0, step=0, start=0; unsigned int adc[8]; unsigned char status[chanel] = {1,2,4,8,16,32,64,128}; int level[chanel] = {400,400,400,400,400,400,400,400}; unsigned char outStatus; //float e, old_e=0,e_sum=0; float error, old_error, Kp=1.2, Kd=10, Ki=0; //int u; int max_e=200, Mid=900,Max; unsigned int read_adc(unsigned char adc_input) { ADMUX=adc_input | (ADC_VREF_TYPE & 0xff); // Delay needed for the stabilization of the ADC input voltage delay_us(200); // Start the AD conversion ADCSRA|=0x40; // Wait for the AD conversion to complete while ((ADCSRA & 0x10)==0); ADCSRA|=0x10; return ADCW; } ////////////////////////DOC TAT CA CAC KENH VAO CUNG NHO MIN///////////////// void read_adc_all() { unsigned char i; unsigned int temp; outStatus = 0; for (i=0; i<chanel; i++) { temp = read_adc(i); if (temp<level[i]) { adc[i]=0; } else { adc[i]=temp; outStatus |= status[i]; } delay_us(50); } if (start ==0) { if ((adc[1]>0)&&(adc[2]>0)&&(adc[3]>0)&&(adc[4]>0)&&(adc[5]>0)&&(adc[6]>0)) { start=1; count++; } } else if ((adc[2]==0)||(adc[3]==0)||(adc[4]==0)||(adc[5]==0))start=0; } /////////////////////// TINH VI TRI XE///////////////////////////////////// int vitrixe() { char j; unsigned int sum1=0, sum2=0; float temp; read_adc_all(); for (j=0; j<chanel;j++) { sum1=sum1+adc[j]*(j+1); sum2=sum2+adc[j]; } if (sum2!=0) { temp = (float)sum1*100; temp = temp/sum2; } else temp=0; return temp-450; } //--------------------------------------------------- int PID_control() { float delta, Udk; int error_sum=0; error =(float)vitrixe(); // Sai so dieu khien if ((error<-350) && (old_error>=0)) {error=-error;} delta = (error - old_error); old_error = error; //Luu gia tri sai so error_sum = error_sum+error; // Thanh phan tich phan // Khong cho thanh phan tich phan vuot qua gia tri max if (error_sum <-max_e) error_sum = -max_e; if (error_sum > max_e) error_sum = max_e; Udk = Kp*error + Ki*error_sum + Kd*delta; //Tin hieu dieu khien // Giam sat gia tri dieu khien ko duoc vuot qua ngwong if (Udk <-Max) Udk = -Max; if (Udk > Max) Udk = Max; return (int)Udk; } void main(void) { unsigned char lcd_buffer[16]; int duong, am; // float delta; int Udk; //unsigned int temp=0; // Declare your local variables here // Input/Output Ports initialization // Port A initialization // Func7=In Func6=In Func5=In Func4=In Func3=In Func2=In Func1=In Func0=In // State7=T State6=T State5=T State4=T State3=T State2=T State1=T State0=T PORTA=0x00; DDRA=0x00; // Port B initialization // Func7=In Func6=In Func5=In Func4=In Func3=In Func2=In Func1=In Func0=In // State7=T State6=T State5=T State4=T State3=T State2=T State1=T State0=T PORTB=0x00; DDRB=0x00; // Port C initialization // Func7=In Func6=In Func5=In Func4=In Func3=In Func2=In Func1=In Func0=In // State7=T State6=T State5=T State4=T State3=T State2=T State1=T State0=T PORTC=0x00; DDRC=0x00; // Port D initialization // Func7=In Func6=In Func5=Out Func4=Out Func3=In Func2=In Func1=In Func0=In // State7=T State6=T State5=0 State4=0 State3=T State2=T State1=T State0=T PORTD=0x00; DDRD=0x30; // Timer/Counter 0 initialization // Clock source: System Clock // Clock value: Timer 0 Stopped // Mode: Normal top=0xFF // OC0 output: Disconnected TCCR0=0x00; TCNT0=0x00; OCR0=0x00; // Timer/Counter 1 initialization // Clock source: System Clock // Clock value: 125.000 kHz // Mode: Fast PWM top=ICR1 // OC1A output: Non-Inv. // OC1B output: Non-Inv. // Noise Canceler: Off // Input Capture on Rising Edge // Timer1 Overflow Interrupt: Off // Input Capture Interrupt: Off // Compare A Match Interrupt: Off // Compare B Match Interrupt: Off TCCR1A=0xA2; TCCR1B=0x5B; TCNT1H=0x00; TCNT1L=0x00; ICR1H=0x03; ICR1L=0xFF; OCR1AH=0x3; OCR1AL=0xff; OCR1BH=0x3; OCR1BL=0xff; // Timer/Counter 2 initialization // Clock source: System Clock // Clock value: Timer2 Stopped // Mode: Normal top=0xFF // OC2 output: Disconnected ASSR=0x00; TCCR2=0x00; TCNT2=0x00; OCR2=0x00; // External Interrupt(s) initialization // INT0: Off // INT1: Off // INT2: Off MCUCR=0x00; MCUCSR=0x00; // Timer(s)/Counter(s) Interrupt(s) initialization TIMSK=0x00; // USART initialization // USART disabled UCSRB=0x00; // Analog Comparator initialization // Analog Comparator: Off // Analog Comparator Input Capture by Timer/Counter 1: Off ACSR=0x80; SFIOR=0x00; // ADC initialization // ADC Clock frequency: 125.000 kHz // ADC Voltage Reference: AREF pin // ADC Auto Trigger Source: Free Running ADMUX=ADC_VREF_TYPE & 0xff; ADCSRA=0xA6; SFIOR&=0x1F; // SPI initialization // SPI disabled SPCR=0x00; // TWI initialization // TWI disabled // Alphanumeric LCD initialization // Connections specified in the // Project|Configure|C Compiler|Libraries|Alphanumeric LCD menu: // RS - PORTC Bit 7 // RD - PORTC Bit 6 // EN - PORTC Bit 5 // D4 - PORTC Bit 4 // D5 - PORTC Bit 3 // D6 - PORTC Bit 2 // D7 - PORTC Bit 1 // Characters/line: 16 lcd_init(16); TWCR=0x00; Max = 1023-Mid; max_e=Mid/4; while (1) { Udk = PID_control(); if (Udk==Max) { am = Mid-Udk*10; if (am<0) am = 0; duong = Mid+Udk; } else if (Udk==-Max) { duong = Mid+Udk*10; if (duong<0) duong = 0; am = Mid-Udk; } else { am = Mid - Udk; duong = Mid +Udk; } if((count==4)||(count==8)||(count==13)||(count>13)) { //delay_ms(100); OCR1A=0; OCR1B=0; count++; delay_ms(1000); } else { OCR1A=am; OCR1B=duong; } //* sprintf(lcd_buffer,"Vi tri xe = %d",vitrixe()); sprintf(lcd_buffer,"%d %d %d %d",adc[0],adc[1],adc[2],adc[3]); lcd_gotoxy(0,0); lcd_puts(lcd_buffer); sprintf(lcd_buffer,"%d %d %d %d",adc[4],adc[5],adc[6],adc[7]); //sprintf(lcd_buffer,"Udk = %d",(int)Udk); lcd_gotoxy(0,1); lcd_puts(lcd_buffer); } }
09-21-2014, 07:10 PM #25
Gửi bởi mta_cdt
return temp-450;
Max = 1023-Mid;
max_e=Mid/4;
09-21-2014, 08:07 PM #26
Gửi bởi trantu93
09-21-2014, 08:33 PM #27
Gửi bởi daotruongpro
.mong mấy bác chỉ bảo với.
09-22-2014, 02:53 AM #28
Gửi bởi trantu93
Chia sẻ - Điều khiển động cơ bằng phương pháp PID hiển thị LCD | Cộng đồng cơ điện tử Việt Nam | Mechatronics
09-21-2015, 05:40 PM #29
Gửi bởi THUONGDTQB
11-06-2015, 06:48 PM #30
Gửi bởi mta_cdt
Svakom Vick là gì? Công dụng và...
Hôm qua, 09:47 PM in Rao vặt tổng hợp
