Chủ đề: MPU 6050 VỚI PIC16F877A
05-07-2016, 06:07 PM #1
em mới làm cái này mong mọi người chỉ với, e có đọc code trên mạng k hiểu chỗ hàm set_tick va get_tick. mọi người giải thích và cho e xin 2 hàm này với. tks!
Mã:#include <16F877A.h> #device ADC=10 #FUSES NOWDT //No Watch Dog Timer #FUSES NOBROWNOUT //No brownout reset #FUSES NOLVP //No low voltage prgming, B3(PIC16) or B5(PIC18) used FOR I/O #use delay(crystal=12MHz) //#use i2c(master, sda=PIN_C4, scl=PIN_C3,FORCE_HW) //#use i2c(master, sda=PIN_E0, scl=PIN_E1) #define MPU_SDA PIN_E0 #define MPU_SCL PIN_E1 #use I2C(master, sda=MPU_SDA, scl=MPU_SCL) //#use TIMER(TIMER=1, TICK=1ms, BITS=16, NOISR) #define LCD_RS_PIN PIN_D0 #define LCD_RW_PIN PIN_D1 #define LCD_ENABLE_PIN PIN_D2 #define LCD_DATA4 PIN_D4 #define LCD_DATA5 PIN_D5 #define LCD_DATA6 PIN_D6 #define LCD_DATA7 PIN_D7 #include <lcd.c> #include "MPU6050.c" #include "math.h" #include "Kalman.h" #define RAD_TO_DEG 180/PI void main() { SIGNED int16 accX,accY, accZ; SIGNED int16 gyroX,gyroY,gyroZ; DOUBLE accXangle,accYangle; DOUBLE gyroXangle,gyroYangle; DOUBLE kalAngleX,kalAngleY; UNSIGNED int16 timer; lcd_init (); printf (LCD_PUTC, "\f MuaLinhKien.Vn PIC 16/18 Basic Kit"); delay_ms (1000); printf (LCD_PUTC, "\f"); Mpu6050_Init () ; delay_ms (500) ; INT8 x; x = Mpu6050_Read(MPU6050_RA_WHO_AM_I); IF (x != 0x68) { LCD_Gotoxy (2, 0) ; printf (LCD_PUTC, "Connection ERR!!!"); return; } WHILE (true) { accX = Mpu6050_GetData (MPU6050_RA_ACCEL_XOUT_H); accY = Mpu6050_GetData (MPU6050_RA_ACCEL_YOUT_H); accZ = Mpu6050_GetData (MPU6050_RA_ACCEL_ZOUT_H); gyroX = Mpu6050_GetData(MPU6050_RA_GYRO_XOUT_H); gyroY = Mpu6050_GetData(MPU6050_RA_GYRO_YOUT_H); gyroZ = Mpu6050_GetData(MPU6050_RA_GYRO_ZOUT_H); //! lcd_gotoxy(1,1); //! printf(LCD_PUTC,"G:X%5lu",gyroX); //! lcd_gotoxy(10,1); //! printf(LCD_PUTC,"Y%5lu",gyroY); //! lcd_gotoxy(1,2); //! printf(LCD_PUTC,"Z%5lu",gyroZ); //! delay_ms(100); //! lcd_gotoxy(1,1); //! printf(LCD_PUTC,"A:X%5lu",accX); //! lcd_gotoxy(10,1); //! printf(LCD_PUTC,"Y%5lu",accY); //! lcd_gotoxy(1,2); //! printf(LCD_PUTC,"Z%5lu",accZ); //! Delay_ms( 100 ); set_ticks(0); accXangle = (atan2 (accY, accZ) + PI) * RAD_TO_DEG; DOUBLE gyroXrate = (double) gyroX / 131.0; gyroXangle += gyroXrate * ( (DOUBLE) (get_ticks () - timer) / 1000); kalAngleX = kalmanCalculate (accXangle, gyroXrate, (get_ticks()-timer)); timer = get_ticks (); timer=0; set_ticks(0); accYangle = (atan2 (accX, accZ) + PI) * RAD_TO_DEG; DOUBLE gyroYrate = (double) gyroY / 131.0; gyroYangle += gyroYrate * ( (DOUBLE) (get_ticks () - timer) / 1000); kalAngleY = kalmanCalculate (accYangle, gyroYrate, (get_ticks()-timer)); timer = get_ticks (); LCD_Gotoxy (1, 1) ; printf (LCD_PUTC, "X=%f", kalAngleX); LCD_Gotoxy (10, 1) ; printf (LCD_PUTC, " " ); if(kalAngleX>200) { LCD_Gotoxy (10, 1) ; printf (LCD_PUTC, "back " ); } if((150<kalAngleX)&&(kalAngleX<170)) { LCD_Gotoxy (10, 1) ; printf (LCD_PUTC, "forward" ); } if(kalAngleX<150) { LCD_Gotoxy (10, 1) ; printf (LCD_PUTC, "nitro " ); } LCD_Gotoxy (1, 2) ; printf (LCD_PUTC, "Y=%f", kalAngleY); LCD_Gotoxy (10, 2) ; printf (LCD_PUTC, " " ); if(kalAngleY>200) { LCD_Gotoxy (10, 2) ; printf (LCD_PUTC, "left " ); } if(kalAngleY<160) { LCD_Gotoxy (10, 2) ; printf (LCD_PUTC, "right " ); } delay_ms(100); } }
- xin bộ điều khiển robot
- Cánh tay Robot 2 bậc tự do cơ cấu trượt
- Tổng hợp các kỳ thi Robocon trong và ngoài nước
- The Reaction Wheel Pendulum!
- Cần giúp đỡ sử dụng matlab mô phỏng và điều khiển robot
- Cần giúp đỡ
- Dò Line dùng ADC Avr + CB Siêu âm - BK-VS
- bánh xe đa hướng omni
- Giáo trình Robocon
- Bậc của hệ phi tuyến này ?
Svakom Vick là gì? Công dụng và...
Hôm qua, 09:47 PM in Rao vặt tổng hợp
