Kết quả 1 đến 4 của 4
08-15-2014, 07:33 AM #1
- Hà Nội, Việt Nam
Robotics, Vision and Control Fundamental Algorithms in MATLAB
Tặng các bạn cuốn sách này.
Mình có bản PDF mà quá nặng, tới 191 MB nên mình upload bản DJVU chỉ có 17.2 MB (chất lượng PDF thì zoom cỡ 400% mới thấy khác biệt).
- Tutorial introduction to robotics and vision
- Easy to read and absorb, including Matlab examples and lots of figures
- Written in a light but informative style, easy-to-read and absorb, and includes a lot of Matlab examples and figures
- Explains how to choose the right algorithm for a particular problem how to try it out without spending days coding and debugging
- Makes the algorithms accessible (so author’s Toolbox code can be read to gain understanding) and provides instant gratification in just a couple of lines of MATLAB code
- Demonstrates how the code can also be the starting point for new work via writing programs based on Toolbox functions, or modifying the Toolbox code itself
- Shows how complex problems can be decomposed and solved using just a few simple lines of code, and hopefully to inspire up and coming researchers
- Walk through the fundamentals of robot kinematics, dynamics and joint level control, then camera models, image processing, feature extraction and epipolar geometry, then bring it all together in a visual servo system
The author has maintained two open-source MATLAB Toolboxes for more than 10 years: one for robotics and one for vision. The key strength of the Toolboxes provide a set of tools that allow the user to work with real problems, not trivial examples. For the student the book makes the algorithms accessible, the Toolbox code can be read to gain understanding, and the examples illustrate how it can be used —instant gratification in just a couple of lines of MATLAB code. The code can also be the starting point for new work, for researchers or students, by writing programs based on Toolbox functions, or modifying the Toolbox code itself.
The purpose of this book is to expand on the tutorial material provided with the toolboxes, add many more examples, and to weave this into a narrative that covers robotics and computer vision separately and together. The author shows how complex problems can be decomposed and solved using just a few simple lines of code, and hopefully to inspire up and coming researchers. The topics covered are guided by the real problems observed over many years as a practitioner of both robotics and computer vision. It is written in a light but informative style, it is easy to read and absorb, and includes a lot of Matlab examples and figures. The book is a real walk through the fundamentals of robot kinematics, dynamics and joint level control, then camera models, image processing, feature extraction and epipolar geometry, and bring it all together in a visual servo system.View more random threads:
- xin tài liệu
- Chia sẻ 1 số tài liệu sưu tầm
- Xin tài liệu olyimpic nguyên lý máy
- Ứng dụng của bộ chia tín hiệu 4-20mA
- Giáo trình cảm biến Công Nghiệp
- Code giao tiếp card reader (RFID) thẻ từ của siemens theo Wiegand serial standard
- Tài liệu vip giáo trình hướng dẫn thiết kế khuôn proe
- điều khiển động cơ bldc
- xin sơ đồ tivi JVC C1480M
- EBOOKBKMT - TỰ ĐỘNG HÓA THIẾT KẾ CƠ KHÍ (PGS.TS.TRỊNH CHẤT & TS. TRỊNH ĐỒNG TÍNH)
08-15-2014, 07:49 AM #2
bạn gửi bản PDF lên, mình giảm dung lượng cho, có thể search dc sau khi OCR
08-15-2014, 09:27 AM #3
- Khu ĐTM Định Công, Hoàng Mai, Hà Nội
Bản PDF này không cần OCR vì nó không phải dạng scan.
Mình nghĩ không cần thiết đâu. Bản DJVU cũng y chang à. Tốn băng thông thôi chứ không ích gì.
08-26-2014, 11:09 PM #4
đọc kiểu j vậy bác?
Locked In Pee – Có gì bên trong...
