    tại sao lại bị lỗi xuất gcode
    Pro/NC-GPOST Mill Version 6.4 P-10.0, Copyright(c) 2010
    Date=10-20-2015 Time=16:24:44
    Input File=D:\document\creo \gcodemoinhat.ncl.1
    Post Name=C:\Program Files\PTC\Creo 2.0\Parametric\bin\..\..\Common Files\M110\x86e_win64\gpost\uncx01.p14
    Option File=uncx01.p14
    Filter File=uncx01.f14
    1 Pro/NC-GPOST FIL 06.400.WN00
    -1 INCLUD/UNCMIL.V00
    -2 $$ GPOST MILL SYSTEM VOCABULARY TABLE
    -3 PPWORD/TLANGL,1
    -4 PPWORD/RETURN,7
    -5 PPWORD/RTRCTO,7
    -6 PPWORD/STEP,66
    -7 PPWORD/ABSOL,90
    -8 PPWORD/HOLDIA,157
    -9 PPWORD/OSETNO,159
    -10 PPWORD/BRKCHP,216
    -11 PPWORD/HED,238
    -12 PPWORD/OFSETL,275
    -13 PPWORD/DWELL,279
    -14 PPWORD/FEDTO,281
    -15 PPWORD/DEPTH,281
    -16 PPWORD/CLEAR,280
    -17 PPWORD/RAPTO,280
    -18 PPWORD/INCH,303
    -19 PPWORD/CORNER,403
    -20 PPWORD/DIAMET,157
    -21 PPWORD/OFSTNO,1074
    -22 PPWORD/CALSUB,3150
    -23 PPWORD/DEFSUB,3151
    -24 PPWORD/ENDSUB,3152
    -25 PPWORD/VERIFY,3153
    -26 PPWORD/3DCOMP,3155
    -27 PPWORD/BACK,3156
    -28 PPWORD/PNT,3157
    -29 PPWORD/CALIB,3158
    -30 PPWORD/PROTCT,3159
    -31 PPWORD/SCAN,3160
    -32 PPWORD/PERMIN,3161
    -33 PPWORD/RCTNGL,3162
    -34 PPWORD/XDIM,3163
    -35 PPWORD/YDIM,3164
    -36 PPWORD/ROUND,3165
    -37 PPWORD/XDIST,3166
    -38 PPWORD/YDIST,3167
    -39 PPWORD/DIST,3168
    -40 PPWORD/CUTS,3169
    -41 PPWORD/FINCUT,3170
    -42 PPWORD/TLAXIS,3171
    -43 PPWORD/PROBE,3172
    -44 PPWORD/WIRE,3173
    -45 PPWORD/UNLOAD,3174
    -46 PPWORD/DIPM,3175
    -47 PPWORD/TORCH,3176
    -48 PPWORD/APPLY,3177
    -49 PPWORD/PIERCE,3178
    -50 PPWORD/YDIR,3179
    -51 PPWORD/XDIR,3180
    -52 PPWORD/FLAME,3181
    -53 PPWORD/PUNCH,3182
    -54 PPWORD/CLDIST,3183
    -55 PPWORD/SYNCTR,3184
    -56 PPWORD/UPPER,3185
    -57 PPWORD/LOWER,3186
    -58 PPWORD/FLUSH,3187
    -59 PPWORD/GENRTR,3188
    -60 PPWORD/CONST,3189
    -61 PPWORD/WATTS,3190
    -62 PPWORD/LASER,3191
    -63 INCLUD/UNCMIL.S00
    -64 $$ GPOST MILL SYSTEM STARTUP FILE
    -65
    -66 REDEF/ON
    -67
    -68
    -69 A=1;B=2;C=3;D=4;E=5;F=6;G=7;H=8;I=9;J=10;K=11;L=12 ;M=13;N=14
    -70 O=15;P=16;Q=17;R=18;S=19;T=20;U=21;V=22;W=23;X=24; Y=25;Z=26
    -71
    -72
    -73 $$ ************************************************** **
    -74 $$ * L O A D T L S E C T I O N S *
    -75 $$ ************************************************** **
    -76
    -77 CIMFIL/ON,LOADTL
    -78 $$ ADD OFFSET NUMBER IF NOT PROGRAMMED
    -79 NBEL=POSTF(5) $$ NUMBER OF WORD
    -80 IF (NBEL.EQ.4) THEN
    -81 $$ ONLY THE TOOL NUMBER HAS BEEN PROGRAMMED
    -82 $$ ADD ADJUST, OFFSET NUMBER=TOOL
    -83 DMY=POSTF(9,5,(ICODEF(ADJUST)))
    -84 DMY=POSTF(10,6,(POSTF(7,4)))
    -85 $$ INCREASE NUMBER OF WORD
    -86 DMY=POSTF(12,6)
    -87 ENDIF
    -88 $$ PROCESS RECORD
    -89 DMY=POSTF(13)
    -90 CIMFIL/OFF
    -91
    -92
    -93 $$ ************************************************** **
    -94 $$ * C U T C O M S E C T I O N S *
    -95 $$ ************************************************** **
    -96 CIMFIL/ON,CUTCOM
    -97 $$ THIS FIL IS USED TO SET A DEFAULT DIAMETER OFFSET NUMBER
    -98 SETV=POSTF(7,4) $$ GET THE 4TH CL WORD
    -99 SETT=POSTF(6,4) $$ GET THE TYPE OF THE 4TH CL WORD
    -100 NBEL=POSTF(5) $$ NUMBER OF WORD
    -101 IF(SETT.EQ.0.AND.SETV.NE.(ICODEF(OFF)).AND.NBEL.EQ .4)THEN
    -102 $$ DEFAULT OFFSET NUMBER TO CURRENT TOOL NUMBER
    -103 DMY=POSTF(10,5,(POSTF(1,3,497)))
    -104 $$ CHANGE NUMBER OF ARGUMENT
    -105 DMY=POSTF(12,5)
    -106 ENDIF
    -107 $$ EXECUTE THE CURRENT RECORD (MODIFIED OR NOT``)
    -108 DMY=POSTF(13)
    -109 CIMFIL/OFF
    -110
    -111
    -112 $$ ************************************************** **
    -113 $$ * P P R I N T S E C T I O N S *
    -114 $$ ************************************************** **
    -115
    -116 CIMFIL/ON,PPRINT
    -117 $$ MACRO ON PPRINT TO IGNORE PPRINT
    -118 $$ WITH THE WORD COMMENTS
    -119 MESS=TEXT/CLW
    -120 COM=TEXT/'COMMENTS'
    -121 RSLT=INDXF(MESS,COM)
    -122 IF (RSLT.EQ.0) THEN
    -123 $$ PROCESS THE PPRINT
    -124 PPRINT/MESS
    -125 ENDIF
    -126 CIMFIL/OFF
    -127
    -128
    -129 $$ ************************************************** **
    -130 $$ * F I N I S E C T I O N S *
    -131 $$ ************************************************** **
    -132
    -133 CIMFIL/ON,14 $$ FINI STATEMENT
    -134 DMY=POSTF(20) $$ SAVE THE CURRENT RECORD
    -135 AUXFUN/30 $$ OUTPUT M30
    -136 DMY=POSTF(21) $$ RECAL SAVED RECORD
    -137 DMY=POSTF(13) $$ PROCESS THE RECORD
    -138 CIMFIL/OFF
    -139 INCLUD/UNCMIL.F00
    -140 $$ ************************************************** **
    -141 $$ * SYSTEM MILL FIL *
    -142 $$ ************************************************** **
    -143
    -144 PRINT/OFF,IN $$ USE FOR PRODUCTION
    1
    1>PARTNO / MFG0001
    2>MACHIN/,14
    8>UNITS/INCH
    9>LOADTL/1,OSETNO,1
    1 Pro/NC-GPOST Mill UNCX01 6.4.WN00 P-10.0 BUILD=0083 MACHIN/UNCX01,14 DATE: 10/20/2015 PAGE 1
    FADAL VMC15 - CNC 32MP
    / MFG0001 (INCH)
    INPUT CLREC N4G2E2X34Y34Z34P13Q2R34I34J34K34F33D2H2S4T5M2
    9 9 $ / MFG0001
    9 9 %$
    9 9 N1 T1 M6$
    11>CAMERA/1,0,0,0,0,1,0,0,0,0,1,0
    12>SPINDL/RPM,1200,CLW
    12 12 N2 S1200 M3$
    13>RAPID
    14>GOTO /-5.829653,27.133333,5
    14 14 N3 G0 X-5.8297 Y27.1333$
    14 14 N4 G43 Z5. H1$
    15>FEDRAT/20,IPM
    16>GOTO /-5.829653,27.133333,-2
    16 16 N5 G1 Z-2. F20.$
    17>GOTO /-17,27.133333,-2
    17 17 N6 X-17.$
    18>GOTO /-17,22.2,-2
    18 18 N7 Y22.2$
    19>GOTO /-8.423298,22.2,-2
    19 19 N8 X-8.4233$
    21>ARCDAT/0,20.92,-2,0,0,1,8.519997
    22>GOTO /-8.519997,20.92,-2
    22 23 N9 G3 X-8.52 Y20.92 I8.4233 J-1.28$
    23>GOTO /-8.52,20.92,-2
    23 23 N10 G1 X-8.52 Y20.92 Z-2.$
    24>GOTO /-8.52,17.266667,-2
    24 24 N11 Y17.2667$
    25>GOTO /-17,17.266667,-2
    25 25 N12 X-17.$
    26>GOTO /-17,12.333333,-2
    26 26 N13 Y12.3333$
    27>GOTO /-8.52,12.333333,-2
    27 27 N14 X-8.52$
    28>GOTO /-8.52,9.146562,-2
    28 28 N15 Y9.1466$
    30>ARCDAT/0,0,-2,0,0,1,12.5
    31>GOTO /-10.074224,7.400001,-2
    31 32 N16 G3 X-10.0742 Y7.4 I8.52 J-9.1466$
    32>GOTO /-10.074223,7.4,-2
    32 32 N17 G1 X-10.0742 Y7.4 Z-2.$
    33>GOTO /-17,7.4,-2
    33 33 N18 X-17.$
    34>GOTO /-17,2.466667,-2
    34 34 N19 Y2.4667$
    35>GOTO /-12.254202,2.466667,-2
    35 35 N20 X-12.2542$
    1
    37>ARCDAT/0,0,-2,0,0,1,12.499997
    38>GOTO /-12.254202,-2.466667,-2
    38 39 N21 G3 X-12.2542 Y-2.4667 I12.2542 J-2.4667$
    39>GOTO /-17,-2.466667,-2
    39 39 N22 G1 X-17.$
    40>GOTO /-17,-7.4,-2
    40 40 N23 Y-7.4$
    41>GOTO /-10.074223,-7.4,-2
    41 41 N24 X-10.0742$
    43>ARCDAT/0,0,-2,0,0,1,12.499999
    44>GOTO /-8.519999,-9.146561,-2
    44 45 N25 G3 X-8.52 Y-9.1466 I10.0742 J7.4$
    45>GOTO /-8.52,-9.146562,-2
    45 45 N26 G1 X-8.52 Y-9.1466 Z-2.$
    46>GOTO /-8.52,-12.333333,-2
    46 46 N27 Y-12.3333$
    47>GOTO /-17,-12.333333,-2
    47 47 N28 X-17.$
    48>GOTO /-17,-17.266667,-2
    48 48 N29 Y-17.2667$
    49>GOTO /-8.52,-17.266667,-2
    49 49 N30 X-8.52$
    50>GOTO /-8.52,-20.92,-2
    50 50 N31 Y-20.92$
    52>ARCDAT/0,-20.92,-2,0,0,1,8.52
    53>GOTO /-8.423301,-22.2,-2
    53 54 N32 G3 X-8.4233 Y-22.2 I8.52 J0.$
    54>GOTO /-8.423298,-22.2,-2
    54 54 N33 G1 X-8.4233 Y-22.2 Z-2.$
    55>GOTO /-17,-22.2,-2
    55 55 N34 X-17.$
    56>GOTO /-17,-27.133333,-2
    56 56 N35 Y-27.1333$
    57>GOTO /-5.829653,-27.133333,-2
    57 57 N36 X-5.8297$
    59>ARCDAT/0,-20.92,-2,0,0,1,8.519998
    60>GOTO /-.530746,-29.423451,-2
    60 61 N37 G3 X-.5307 Y-29.4235 I5.8297 J6.2133$
    61>GOTO /-.530745,-29.423449,-2
    61 61 N38 G1 X-.5307 Y-29.4235 Z-2.$
    62>GOTO /17,-37,-2
    62 62 N39 X17. Y-37.$
    63>GOTO /-17,-37,-2
    63 63 N40 X-17.$
    64>GOTO /-17,-32.066667,-2
    64 64 N41 Y-32.0667$
    65>GOTO /17,-32.066667,-2
    65 65 N42 X17.$
    66>GOTO /17,-27.133333,-2
    1
    66 66 N43 Y-27.1333$
    67>GOTO /5.829653,-27.133333,-2
    67 67 N44 X5.8297$
    69>ARCDAT/0,-20.92,-2,0,0,1,8.519998
    70>GOTO /8.423299,-22.2,-2
    70 71 N45 G3 X8.4233 Y-22.2 I-5.8297$
    71>GOTO /8.423298,-22.2,-2
    71 71 N46 G1 X8.4233 Y-22.2 Z-2.$
    72>GOTO /17,-22.2,-2
    72 72 N47 X17.$
    73>GOTO /17,-17.266667,-2
    73 73 N48 Y-17.2667$
    74>GOTO /8.52,-17.266667,-2
    74 74 N49 X8.52$
    75>GOTO /8.52,-12.333333,-2
    75 75 N50 Y-12.3333$
    76>GOTO /17,-12.333333,-2
    76 76 N51 X17.$
    77>GOTO /17,-7.4,-2
    77 77 N52 Y-7.4$
    78>GOTO /10.074223,-7.4,-2
    78 78 N53 X10.0742$
    80>ARCDAT/0,0,-2,0,0,1,12.499999
    81>GOTO /12.254204,-2.466667,-2
    81 82 N54 G3 X12.2542 Y-2.4667 I-10.0742 J7.4$
    82>GOTO /12.254202,-2.466667,-2
    82 82 N55 G1 X12.2542 Y-2.4667 Z-2.$
    83>GOTO /17,-2.466667,-2
    83 83 N56 X17.$
    84>GOTO /17,2.466667,-2
    84 84 N57 Y2.4667$
    85>GOTO /12.254202,2.466667,-2
    85 85 N58 X12.2542$
    87>ARCDAT/0,0,-2,0,0,1,12.499997
    88>GOTO /10.074221,7.399999,-2
    88 89 N59 G3 X10.0742 Y7.4 I-12.2542 J-2.4667$
    89>GOTO /10.074223,7.4,-2
    89 89 N60 G1 X10.0742 Y7.4 Z-2.$
    90>GOTO /17,7.4,-2
    90 90 N61 X17.$
    91>GOTO /17,12.333333,-2
    91 91 N62 Y12.3333$
    92>GOTO /8.52,12.333333,-2
    92 92 N63 X8.52$
    93>GOTO /8.52,17.266667,-2
    93 93 N64 Y17.2667$
    94>GOTO /17,17.266667,-2
    94 94 N65 X17.$
    95>GOTO /17,22.2,-2
    1
    95 95 N66 Y22.2$
    96>GOTO /8.423298,22.2,-2
    96 96 N67 X8.4233$
    98>ARCDAT/0,20.92,-2,0,0,1,8.519997
    99>GOTO /5.829653,27.133333,-2
    99 100 N68 G3 X5.8297 Y27.1333 I-8.4233 J-1.28$
    100>GOTO /5.829653,27.133333,-2
    100 100 N69 G1 X5.8297 Y27.1333 Z-2.$
    101>GOTO /17,27.133333,-2
    101 101 N70 X17.$
    102>GOTO /17,32.066667,-2
    102 102 N71 Y32.0667$
    103>GOTO /-17,32.066667,-2
    103 103 N72 X-17.$
    104>GOTO /-17,37,-2
    104 104 N73 Y37.$
    105>GOTO /17,37,-2
    105 105 N74 X17.$
    106>GOTO /8.52,20.92,-2
    106 106 N75 X8.52 Y20.92$
    107>GOTO /8.52,9.146562,-2
    107 107 N76 Y9.1466$
    109>ARCDAT/0,0,-2,0,0,-1,12.5
    110>GOTO /8.52,-9.146562,-2
    110 111 N77 G2 X8.52 Y-9.1466 I-8.52 J-9.1466$
    111>GOTO /8.52,-20.92,-2
    111 111 N78 G1 Y-20.92$
    112>GOTO /8.52,-20.92,-2
    112 112 N79 X8.52 Y-20.92 Z-2.$
    114>ARCDAT/0,-20.92,-2,0,0,-1,8.52
    115>GOTO /-6.570131,-26.344369,-2
    115 117 N80 G2 X-8.52 Y-20.92 J0.$
    117>GOTO /-8.52,-9.146562,-2
    117 117 N81 G1 Y-9.1466$
    119>ARCDAT/0,0,-2,0,0,-1,12.5
    120>GOTO /-8.52,9.146562,-2
    120 121 N82 G2 X-8.52 Y9.1466 I8.52 J9.1466$
    121>GOTO /-8.52,20.92,-2
    121 121 N83 G1 Y20.92$
    122>GOTO /-8.52,20.92,-2
    122 122 N84 X-8.52 Y20.92 Z-2.$
    124>ARCDAT/0,20.92,-2,0,0,-1,8.52
    125>GOTO /6.570132,26.344368,-2
    125 127 N85 G2 X8.52 Y20.92 J0.$
    127>GOTO /8.52,20.92,5
    127 127 N86 G1 Z5.$
    128>RAPID
    129>GOTO /17,-37,5
    129 129 N87 G0 X17. Y-37.$
    1
    130>FEDRAT/20,IPM
    131>GOTO /17,-37,-2
    131 131 N88 G1 Z-2. F20.$
    132>GOTO /17,37,-2
    132 132 N89 Y37.$
    133>GOTO /-17,37,-2
    133 133 N90 X-17.$
    134>GOTO /-17,-37,-2
    134 134 N91 Y-37.$
    135>GOTO /17,-37,-2
    135 135 N92 X17.$
    136>GOTO /17,-37,5
    136 136 N93 Z5.$
    137>SPINDL/OFF
    137 137 N94 M5$
    139>AUXFUN/30
    139 139 N95 M30$
    139>FINI
    139 139 %$
    TAPE 13.61 TIME 44.90 WARNING 0
    1
    TOOL SEQUENCE
    INPUT CLREC TOOL OFFSET LENGTH Z
    9 9 1 1 .0000
    X-AXIS Y-AXIS Z-AXIS
    POST-MINIMUM -17.0000 -37.0000 -2.0000
    POST-MAXIMUM 17.0000 37.0000 5.0000
    TAPE-MINIMUM -17.0000 -37.0000 -2.0000
    TAPE-MAXIMUM 17.0000 37.0000 5.0000
    A-AXIS B-AXIS C-AXIS
    POST-MINIMUM .0000 .0000 .0000
    POST-MAXIMUM .0000 .0000 .0000
    TAPE-MINIMUM .0000 .0000 .0000
    TAPE-MAXIMUM .0000 .0000 .0000
    -3 PPWORD/TLANGL,1
    -4 PPWORD/RETURN,7
    -5 PPWORD/RTRCTO,7
    -6 PPWORD/STEP,66
    -7 PPWORD/ABSOL,90
    -11 PPWORD/HED,238
    -18 PPWORD/INCH,303
    -28 PPWORD/PNT,3157
    -65
    -66 REDEF/ON
    -67
    -68
    -71
    -72
    -76
    -86 DMY=POSTF(12,6)
    -87 ENDIF
    -89 DMY=POSTF(13)
    -90 CIMFIL/OFF
    -91
    -92
    -106 ENDIF
    -108 DMY=POSTF(13)
    -109 CIMFIL/OFF
    -110
    -111
    -115
    -119 MESS=TEXT/CLW
    -124 PPRINT/MESS
    -125 ENDIF
    -126 CIMFIL/OFF
    -127
    -128
    -132
    -138 CIMFIL/OFF
    -143
    1
    1>PARTNO / MFG0001
    2>MACHIN/,14
    8>UNITS/INCH
    9>LOADTL/1,OSETNO,1
    / MFG0001 (INCH)
    9 9 $ / MFG0001
    9 9 %$
    9 9 N1 T1 M6$
    12 12 N2 S1200 M3$
    13>RAPID
    15>FEDRAT/20,IPM
    17 17 N6 X-17.$
    18 18 N7 Y22.2$
    19 19 N8 X-8.4233$
    24 24 N11 Y17.2667$
    25 25 N12 X-17.$
    26 26 N13 Y12.3333$
    27 27 N14 X-8.52$
    28 28 N15 Y9.1466$
    33>GOTO /-17,7.4,-2
    33 33 N18 X-17.$
    34 34 N19 Y2.4667$
    1
    39 39 N22 G1 X-17.$
    40 40 N23 Y-7.4$
    47 47 N28 X-17.$
    49 49 N30 X-8.52$
    50 50 N31 Y-20.92$
    55 55 N34 X-17.$
    57 57 N36 X-5.8297$
    62>GOTO /17,-37,-2
    63>GOTO /-17,-37,-2
    63 63 N40 X-17.$
    65 65 N42 X17.$
    1
    67 67 N44 X5.8297$
    72 72 N47 X17.$
    74 74 N49 X8.52$
    76 76 N51 X17.$
    77>GOTO /17,-7.4,-2
    77 77 N52 Y-7.4$
    78 78 N53 X10.0742$
    83 83 N56 X17.$
    84 84 N57 Y2.4667$
    85 85 N58 X12.2542$
    90>GOTO /17,7.4,-2
    90 90 N61 X17.$
    91 91 N62 Y12.3333$
    92 92 N63 X8.52$
    93 93 N64 Y17.2667$
    94 94 N65 X17.$
    95>GOTO /17,22.2,-2
    1
    95 95 N66 Y22.2$
    96 96 N67 X8.4233$
    101 101 N70 X17.$
    103 103 N72 X-17.$
    104>GOTO /-17,37,-2
    104 104 N73 Y37.$
    105>GOTO /17,37,-2
    105 105 N74 X17.$
    127 127 N86 G1 Z5.$
    128>RAPID
    129>GOTO /17,-37,5
    1
    130>FEDRAT/20,IPM
    131>GOTO /17,-37,-2
    132>GOTO /17,37,-2
    132 132 N89 Y37.$
    133>GOTO /-17,37,-2
    133 133 N90 X-17.$
    134 134 N91 Y-37.$
    135>GOTO /17,-37,-2
    135 135 N92 X17.$
    136>GOTO /17,-37,5
    136 136 N93 Z5.$
    137>SPINDL/OFF
    137 137 N94 M5$
    139>AUXFUN/30
    139 139 N95 M30$
    139>FINI
    139 139 %$
    1
    TOOL SEQUENCE
    9 9 1 1 .0000
Múi giờ GMT +7. Bây giờ là 06:47 AM. Diễn đàn sử dụng vBulletin® Phiên bản 4.2.5.
